من یه مشکل دارم
یه سرور hp DL380p gen8 دارم به 16 g رم و 3t هارد میخوام چند تا سرور مجازی با Hyper-v راه اندازی کنم الان دو تا win 2008 r2 نصب کردن اما هم زمان نمیتونم هر دو رو استارت کنم هر کدوم که روشن باشه اون یکی پیغام زیر رو میده در ضمن برای هر کدوم 1gig رم و 50gig هم هارد در نظر گرفتم اگه لطف کنید و راهنمایی کنید خیلی ممنون میشم
[Window Title] Hyper-V Manager [Main Instruction] An error occurred while attempting to change the state of virtual machine New Virtual Machine. [Content] 'New Virtual Machine' failed to start. Microsoft Emulated IDE Controller (Instance ID {83F8638B-8DCA-4152-9EDA-2CA8B33039B4}): Failed to power on with Error 'The process cannot access the file because it is being used by another process.' Failed to open attachment 'D:'. Error: 'The process cannot access the file because it is being used by another process.' [Expanded Information] 'New Virtual Machine' failed to start. (Virtual machine 418ACD0E-5FBA-4053-AFDD-1EDA51694EF5) 'New Virtual Machine' Microsoft Emulated IDE Controller (Instance ID {83F8638B-8DCA-4152-9EDA-2CA8B33039B4}): Failed to power on with Error 'The process cannot access the file because it is being used by another process.' (0x80070020). (Virtual machine 418ACD0E-5FBA-4053-AFDD-1EDA51694EF5) 'New Virtual Machine': Failed to open attachment 'D:'. Error: 'The process cannot access the file because it is being used by another process.' (0x80070020). (Virtual machine 418ACD0E-5FBA-4053-AFDD-1EDA51694EF5) Cake Hide details [Close]
